Question about the Piezo targets - occasionally I will still use QTR with a printer with OEM inks and after creating a curve I like to check it’s linearity and neutrality by printing a target, measuring, and analyzing the LAB values. I know that the Piezo 256 target is coded with a gamma of 2.2, but assuming that my workflow remains in 2.2, could this target be used for plotting linearization data from a QTR OEM ink workflow? It wouldn’t be used to do the actual linearization, rather just check and see if the curve is linear/neutral. Would I encounter any issues because of the coded gamma in the target?
It will work.
