Starting Point for Blending Curves
Would a good starting point for experimenting with the blender tool be to print a neutral print from a neutral blend of the warm and cool curves to check that the default ‘28’ setting in the blending tool is in fact, accurate for the particular paper ?
Tom
Actually the best way to do this is to load the Warm and Cool curves into QTR (not neutral) and actually just print 28% warm. Then slide around to find the neutral with the sliders first. This will tell you the percentage to use in the blender tool when fine-tuning/making the neutral curve.
Cheers Walker, that worked well.
:slight_smile:
