Some Curves to Share
Hey guys, got some curves to share if you’re interested! NOTE: I’m printing on a 7900 with several dead channels, so my channel mapping is this:
1: HD PK
2: C
3: OR
4: LC
5: Y
6: M
GO: LM
here’s what’s up:
PDN_SFZ_SILVER_ISMWT_20200509.quad:
15 seconds, 3000k LED strips under a vacuum easle with, #00 filter (green gel) and ND gels lining them over my Nuarc’s vacuum easel (only way I can get a sharp print with a 00).
PDN_SFZ_CYANO_AwgPlatGamp_200405.quad:
Printed on the warm base awagami platinum rag. Dilute 1:20 with distilled and 1ml of citric acid, put in a tray and place the paper in and let it absorb it all. 500 units in my Nuarc 26-1Ks
PDN_SFZ_CYANO_HPR_2ml_500u_200409-DiCro.quad
New Cyanotype on Hanhemuhle Platinum Rag, 2ml / 8x10, 2 drops citric, 1 drop tween, 500 units in Nuarc 26-1Ks
PDN_SFZ_CYANO_Platine_200320.quad
New Cyanotype on Arches Platine, 2ml / 8x10, 2 drops citric, 475 units in my Nuarc 26-1Ks
PDN_SFZ_KALI_HPR_2ml_175u_200418.quad
Kalitype on hahnemuhle platinum rag, 1:1 ferric oxalate to silver nitrate (10%), 2ml / 8x10, 1 drop tween per 5ml, 175 units in nuarc 26-1ks
PDN_SFZ_KALI_Platine-B_2ml-FS_85u_200506.quad
Kalitype on Arches Platine, fumed silica pre-coat, 1:1 ferric oxalate to silver nitrate (10%), 2ml / 8x10, 1 drop tween per 5ml, 85 units in nuarc 26-1ks
enjoy!
PDN_SFZ_SILVER_ISMWT_20200509.quad (8.6 KB) PDN_SFZ_KALI_Platine-B_2ml-FS_85u_200506.quad (8.6 KB) PDN_SFZ_KALI_HPR_2ml_175u_200418.quad (8.6 KB) PDN_SFZ_CYANO_HPR_2ml_500u_200409-DiCro.quad (8.7 KB) PDN_SFZ_CYANO_AwgPlatGamp_200405.quad (8.7 KB) PDN_SFZ_CYANO_Platine_200320.quad (8.7 KB)
thanks Xander! Also, I am assuming this was built with Selenium ink set?
best regards,
Yes, this is with selenium
