Hi
I have tried saving my new QTR presets in Print Tool, latest version. Unfortunately it keeps forgetting about them all the time – returning to empty values. I have seen that there is an isssue about Defaults/Last used settings« which is not exactly what I am seeing here. The preset appears in the list but it looks like the information was not save within. Any idea?
Thanks, Markus
You’re not alone in Ventura with the changes to how presets are stored. Have you read this Apple doc?
Hi Jon
That’s what I have been doing for years now - but this time, thanks to Ventura, it does not work properly anymore. The main problem is, that the settings for QuadTone RIP 16 vs 8-bit and bi-directional vs unidirectional do not get saved.
Best, Markus
I would write Roy Harrington at QTR and see if he has a workaround perhaps to counter the OS X changes… he must field this question 100 times a day!
I have done so already - look forward to a solution…
Thanks Walker
I have checked this option as well - but it does not help.
Someparameters can be saved in the (Custom) Preset, some not (16-bit instead of 8-bit, Bi-directional instead of uni-directionl). I have contacted Roy and hope to get a solution from him.
Regards, Markus
I am having the same exact issue in trying to save the printer parameters. Thanks for starting this and hope that Roy or others can help!
Tim
Somehow interesting: it is possible to open QuadTone RIP from the Preview app and prepare all settings as I want them to be. Then I can save the preset – and – at least up to now – these presets can be used in PrintTool as well. Curious whether it works for others too. Right now I am on Ventura, latest version.
Markus
