Questions after installing first linearized curve
I installed my first curve and there are some comments in the box that I do not understand. I am posting a screenshot.
I cannot seem to get the file small enough to be posted. What should the pixel size be?
This is what the install box says:
No default ink limit found, using 4
Could not find gray shadow, using 4
GRAY-GAMMA missing using 1
Do the numbers 4 and 1 refer to the smoothing numbers in the CGATS file?
Thanks.
Catherine
You need to make sure that the curve you are trying to install has a file extension of “.quad” instead of “.txt”
Also, make sure you have all other extraneous left-over .txt files (your -out.txt and your original smoothed measurement .txt) out of the folder before installing.
Thanks, Walker. There was a txt file in the folder.
