QTR settings don\'t show up
Hello Walker,
a software problem shows up:
After the print command in print tool ( v.2.1.1 ) i don’t see the Quadtonerip layout anymore…So i cannot choose a curve etc.
What can be the cause? what do i have to do to solve this problem. I tried reinstalling printtool, rebooting and disconnecting etc. The Quaprinter shows up in the printool app, i just never get the quadtonerip options under Layout…
See picture attached ,
Kind Regards Luc
Check your curve folder and you probably have a .quad with way too many letters (32 char limit on these files).
How to reset: https://piezography.com/install-delete-quadtonerip-curves/
Walker,
this is the case, i created 2 new curves, linearizing 51 steps. The names are to long.
Can i just rename the 2 curves? or do i have to reset following your link?
KR , Luc
You actually do have to follow what I wrote in the link in this case yes. I didn’t type it for no reason. This bug crops up often in QTR but Roy hasn’t fixed it.
