QTR not wanting to cooperate
Hello Jon and Rachel,
I’m at my wits’ end and would appreciate some help:
I’ve recently replaced my Epson 7890 that died with another 7890. Printer alignment and nozzle checks were fine with the original inks so I flushed with PiezoFlush and installed a brand-new set of Pro inks. Nozzle checks look excellent but when I tried to print using the QTR driver and Print-Tool, it wouldn’t print anymore - as in no ink and not even an attempt by the printhead to move across and print something on the 24” roll - it just spat a blank 20x24” section. I ended up reinstalling all the Piezo components on my Mac running 10.14.6: QTR 2.8.2 then PiezoDN 2.8.1, Community Edition 3.3.1 and Print-Tool 2.4.0. I then ran the Quad 7890-PiezoDNPro driver installer and changed all the settings within Print-Tool: 20x24” Centered and QuadToneRIP set to Pro-PiezoDN-Master for Curve 1, Roll Feed, 2880 dpi, uni-directional and PK ink. Now it’s printing but all black and 20” wide regardless of what image I put in Print-Tool!
I realise that the topic of all-black ink has been broached before - and that permissions are often to blame - but I have checked and double-checked to make sure that everything has been opened wide in /Library/Printers/QTR/quadtone (using sudo chmod -R 777 on all folders)…
Any help would be greatly appreciated.
TIA,
Roy
Hi Roy,
Navigate to /Library/Printers/QTR/quadtone/(your printer installation) and confirm that all the curves in the printer you are having this issue with have permissions set to “everyone” as “read & write”. Your getting all black usually is a symptom that they do not. Check info on them and change them in the installed library.
Let us know if that works!
Hi Jon,
I’ve triple-checked and all folders and files within the /Library/Printers/QTR/quadtone folder have Read & Write privileges for everyone… including, of course, the Quad7890-PiezoDNPro folder and the .quad curves within it that I’m using.
Roy
I think I might have found the source of the problem: quadtonerip is missing from the CUPS backend (/usr/libexec/cups/backend), which might explain why the print job is also not paying any attention to the position and format of the test print…
I’m going to try reinstalling QTR completely from scratch tomorrow and will let you know.
If you have any other leads, I’m all ears!
Best regards,
Roy
I thought that you had or I would have suggested it! Also I assumed you can print to the printer through the EPSON driver (even though it will look funny). But that would insure its not a hardware issue with a new to you used printer. The QTR reinstall should do it!
Well, the saga continues! Yes, you’re correct, Jon - PrintTool with the Epson 7890 driver works fine and prints, for example, the LIMITER.tif file as expected (albeit upside-down and not great Dmax). And I did re-install QTR - albeit “lazily” on top of the previous installation.
So today, I got rid of everything Piezo and QTR and did a full install from scratch. Same result (max black ink across the page). I ran the Diagnostic tool and lo and behold it does complain about permissions for the filter (quadtoneprint). I rectified the issue - same result. I did a deep dive into CUPS - resetting everything and even purging the Epson 7890 hardware controller - with, alas, the same result. I swapped Macs and did a fresh install of QTR and everything… I got the same initial result where it spits out an entire 24x20” area without laying down any ink.
This is clearly a communication issue revolving around QTR and CUPS, but I can’t for the life of me see a solution…
-Roy
If the curves have read and write permissions for everyone in Library - then printing black everywhere is mysterious. That is almost always because QTR does not have permission to read those curves when installed in your Library. Make sure you go to the Library curves and check permissions (not the Application folder curves).
That you are also getting blank print jobs…so maybe a CUPs issue. You’re on Mojave and I believe that is when Apple began to force AirPrint so make sure you are on USB or switch to it and see if that repairs the situation. You would need restart before printing. Reinstall the printer. Double check library curves for permissions.
We do not make QTR - so you may have to have a Roy to Roy talk with its author about this.
Hi! This may be something you have done - sorry if I missed it in the preceding thread.
Quit Print-Tool, trash its preference file in ~/Library/Preferences, and relaunch. Print-Tool can hold stale printer or curve settings after an install.
what baffles me is that you tried with another Mac. But did that one already have a prior install of QTR and piezography? If so the prefs folder may also be interfering. Good luck and hope this works out. I’ll keep thinking on it. Pradip
Hi Pradip,
Thanks for the suggestion - it’s very much appreciated. Purging Property Lists is one of the things I tried but to no avail.
But there’s egg on my face - it turns out that my trying to be clever by using cheap Epson paper to troubleshoot my PiezoDN-Pro system has caused a silent clash within QTR: even though the printer didn’t balk at my using PK ink with a Premium Lustre paper setting (IIRC - basically a paper setting that allows PK ink to be used), QTR clearly wasn’t ok with it. I know this now because, out of frustration, I installed a new 7890 Quad-Pro driver for MK ink and a roll of Epson Doubleweight Matte paper. That’s working fine…
The goal has always been to print with QTR and PiezoDN-Pro curves for making digital negatives, but I would really love to know how to use the same PiezoDN setup (i.e. avoid having to switch from PK to MK and back to PK ink) to do testing/troubleshooting on plain/matte paper without using up more of the very expensive Pictorico TPS transparency film than necessary.
TIA for any tips,
Roy
So the saga isn’t over: I’ve gone back to PK ink and my Pictorico roll and the Quad7890-PiezoDNPro driver and it’s acting up again - solid black across the entire width of the roll when I’m feeding it a simple Limiter.tif through Print-Tool (regardless of which PiezoDN-Pro quad I choose).
What gets my goat is I’ve never had this problem before - be it with PiezoDN and K7 inks, the native Epson driver or one of the other drivers such Quad7890-Pro with Matte paper (as mentioned before). This only seems to be happening with the PiezoDN-Pro curves. And yes, I have thoroughly checked permissions: QTR folders (such as filter) all have the necessary 755 permission masks and ownership attributed to root:wheel (as they should) except, of course, all the curves in /Library/Printers/QTR/quadtone that are set to 777.
Any clues? Anyone else had this this problem on Mojave?
  • Mac OS 10.14.6
  • Epson 7890
  • QTR 2.7.9
  • PiezoDN 2.8.1
  • Community Edition 3.3.1
  • Print-Tool 2.3.4
So if you get a blank page while using regular curves for printing your image is not printing - the canvas is but no pixels are being converted.
If you get all black with a PiezoDN curve that is the exact same thing happening. It perceives the canvas as blank. All black means “white” when the negative is contact printed. The PiezoDN curves are inverted.
I can’t tell you why this is happening with your system. But it is related to QTR or CUPS because you indicated it prints normally with the EPSON driver.
Can you do a clean install of Mojave?
Hi Roy,
Before I get into suggestions about the persistent and pesky problem, a thought about using other material for setup and claibrations. Pictorico TPS costs a lot more than Premium Lustre, but I have found it is essential to use the film itself for all calibrations, with PK ink. I’m not familiar with the exact menus on the 7890, but look for a custom paper setting that covers:
  • Platen gap: usually “Narrow”
  • Paper thickness: run the menu command and follow the instructions
  • Paper feed adjustment: run the menu command and follow the instructions
  • Suction: usually “0”
Then save everything as a custom paper setting for the TPS.
This isn’t what’s causing the blank printing. Still, it’s worth doing once a year when you work with a material that renders such fine results. Please don’t use plain paper (or any other substrate) as a stand-in for calibration. Plain paper is fine for nozzle checks, though, and you won’t need to change inks for that.
On the blank output
The persistent problem suggests a communication error between your computer and the new printer. I’d suggest a complete clean reinstall of QTR and PrintTool:
  1. Back up your curves. Copy the curves in Applications > Piezography to your Documents folder or somewhere else, just to be safe.
  2. Remove the QTR files from the system:
    • Delete the QTR folder in /Library/Printers.
    • Delete any QTR-related preference files in /Library/Preferences (system-wide) and ~/Library/Preferences (your user folder).
  3. Delete QTR and PrintTool from the Applications folder. You don’t need to delete Piezography. If you do, make sure you’ve backed up the curves in its Curves folder first.
  4. Reset the printing system. This removes every printer, scanner and fax from your list in one go. Go to System Settings > Printers & Scanners, Control-click any listed device, and choose “Reset Printing System…”
  5. Empty the Trash and reboot.
  6. Reinstall QTR and PrintTool (and Piezography if you trsahed that too).
  7. Re-add the 7890 in System Settings > Printers & Scanners.
  8. Reinstall your curves from Piezography (and the PiezoDN curves).
  9. Check the setup in PrintTool. Make sure the PiezoDN 7890 shows up with your curves. Then go to PrintTool’s Page Setup > Paper and Printer Settings… > Printer Options > QuadTone RIP and confirm that Black Ink is set to “-Installed-”.
I hope this helps, and my apologies if some of it repeats what you’ve already tried. Years ago I had a similar problem, and going through much the same process gave me a happy result.
Pradip
By the way, I upgraded to Monterey (12.7.6) from Mojave around 2024. It works well with my whole QTR/Piezography setup. I have a P7000 with Pro and a 4900 with Carbon inksets.
Hi Pradip,
All your suggestions are very much appreciated - it’s wonderful to have access to such knowledgeable people on forums such as this. It keeps me sane - more or less!
I’ve been through the steps you mention several times - and a few more besides (e.g. also eliminating the relevant files in Caches) - with the only slight deviation being that I chose PK explicitly in the QuadTone RIP settings rather than Installed (not that I can imagine that making a difference).
So, after another full purge of everything related to Piezography and QTR, I decided to go back to basics and installed just QTR 2.7.9 and Print-Tool 2.4.0 on my laptop. I am connected to my Epson 7890 via USB and I used the native QTR Quad 7890 Installer script to install the driver and curves. So far so good. I chose a (native QTR) UCpk-raw-neutral curve inside Print-Tool (closest approximation I believe, given that I have Piezo Pro inks and Pictorico OHP film loaded) and successfully printed my test image (a simple LIMITER.TIF). This would suggest that QTR and communication between my laptop and the printer are both working just fine.
I then installed PiezoDN 2.8.1 again - being very careful to thoroughly check all permissions and ownership: everything 755 with root:wheel ownership except for /Library/Printers QTR/quadtone/ set to 777 (along with all of its enclosed folders and files). I naturally ran the relevant Install script too for the driver and curves.
However, whenever I try to print with any of the PiezoDN-Pro curves using Print-Tool, I get a full black ink dump (i.e. blank canvas since it’s an inverted negative curve) across the width of the 24" roll…
As mentioned, it looks like QTR is working just fine and I don’t believe the Piezography curves are corrupt because, either way, there would be lots of noise about it on the forums…That leaves me with the suspicion that something isn’t quite right with the backend (CUPS) on my system.
So I went back to testing with just the QTR UCpk curve and Print-Tool to try and do some deeper fishing. I set up a sandbox trace and opened Print-Tool and ran the successful job again. I noticed one particular line in the trace:
*** tccd: Prompting policy for hardened runtime; service: kTCCServiceAppleEvents requires entitlement com.apple.security.automation.apple-events but it is missing for ACC:{ID: com.quadtonerip.QTR-Print-Tool, PID[22421]…} ***
I’ve contacted Roy Harrington and asked him to help me debug this but my suspicion is that there is something not quite right with the CUPS backend (broken? quarantine protocol interfering?) and that my OS installation may well be corrupt…
So, in the meantime, I’ve taken my other Mac laptop and am doing a clean install of Mojave and installing everything from scratch…
Best regards,
Roy
Hi Roy,
Ugh, so sorry that the problem persists.
As I mentioned in the post-post, Monterey may be worth trying as an upgrade.
Sanity, it seems, like so much if not everything, is relative don’t you think? Chuckle.
Hang in there.
Pradip
may not achieve permissions in /Library/Printers QTR/quadtone/7890-9890-PiezoDN-Pro
Did you go into /Library/Printers/QTR/quadtone/7890-9890-PiezoDN-Pro and get information on each of the curves inside there and check if everyone is set to read & write? Do not rely on setting permissions directories up from there
Hi Jon,
I set them recursively (chmod -R 777) and yes, I did double-check the curves themselves. I am certain the problem has nothing to do with file permissions…
Best regards,
Roy
