QTR Curves installation - permission denied
Hi
I´v just linarized some curves but they will not install. When running the “Install3880-K7.command” file, terminal reports back “permission denied” for my custom curves, the other curves install just fine. Any thoughts?
Jarle
install-3880-K7-command.tiff (160 KB)
Get info on the whole folder of curves, set the permissions to Read-Write for all, go to the bottom little lock icon and unlock it, and then set “Apply to enclosed items”.
Then install.
Thanks Walker, but still not working. Have changed the Read-Write for the complete QTR program folder but still permission denied.
Jarle
I recommend re-installing QuadtoneRIP. This will also fix permissions.
Many thanks Walker, that did the trick. Superb service by the way…handling this on a saturday!!!
Best regards,
Jarle
Thanks for me, too. BTW what was the studio in Chicago you ran. I just gave away a bunch of ink that went to a community studio in Chicago. About to give a couple hundred more carts that will go that way.
Latitude Chicago, founded :slight_smile:
best!
