I’m trying to import the target .xml files into ColorPort using the Target Manager and not having any luck. Following the standard procedure, everything looks fine but after closing Target Manager and returning to the Measure Target tab, the new target is not in the Select Target drop down list.
Nope. Permissions is not it. I’m wondering if some part of their path in Target Manager is hard coded and it doesn’t like User not living where it’s supposed to.
Yep. It’s definitely related to Users living some place other than the Boot volume. I fixed the problem by manually copying the .xml files to /Documents/ColorPort_Resources/refs/rgb
