Wondering if it’s possible to install use your piezography pro drivers with an ethernet connection? Ideally we would like to print via ethernet rather than through USB, but it seems like the drivers ask specifically for a usb connection?
Just delete all your printers from your queue, then disconnect the printer from USB.
Then double click the install.command from your curves folder and type in the IP address of the printer on the network.
