Printing on silk. Has anyone used
Pieziography ink and .quad curves to print on silk fabric? If so, can you share any of your experiences with doing so. Particularly, which ,quad curve did you use? Thanks!
Yeah, this silk works. http://www.inkjetfabrics.com/products/digital-fabrics/silks/
You’ll want to test with various curves though (matte black ones I think).
The link above sells test rolls.
