I’m scratching my head on this one. It says to install profiles in /Library/ColorSync/Profiles. I put my .icc profile into that directory put I don’t see it. Then I notice in LR that “E38 Test.icc” is “linked” to /Library/ColorSync/Profiles/GH_E3800_EHotPressNatural_021325.icc… which is the name of the icc profile that I added. Why did it use another name other than the one I named it? What can I do to have it recognize/use the file name?
I found what the problem was and I have a workaround. It seems to use the ‘desc’ string in the .icc file instead of the filename. I just went into ColorSync Utility and made the ‘desc’ string equal to the filename.
