Hi, I’m happy to see positive transparencies mentioned, since I am looking for a master POS for the 7900. I generally only use 6 inks, and wonder if the 7th ink in these is essential.
I’ve had very good luck with making positive transparencies with k7 inks and QTR created curves for a couple of years, but something’s gone amiss (I moved and changed platforms and all sorts of things), and I thought it might be a good time to make the change to an all-Piezo method of making curves and printing transparencies.
I fooled with the POS master for 3880 that Walker uploaded a couple of days ago, got the inks repositioned as I need them to be to use on my printer, but can’t get it to install into the 7900 folder. I’m missing something somewhere. I thought simply changing the name would make it work.
Thank-you. I just need the 7900 positive, if you’re pressed for time. I’ve got enough curve making and linearization and nozzle re-assigning under my belt to be able to go from there without hand-holding.
