Hi Walker
We are currently testing a new measurement device MYIRO which is based on the basiCColor software.
Do you know this device/software. Is there an option that they will be supported for creating custom profiles for Piezography Pro?
Thank you for your reply and best regards
Markus
This is a re-brand of the Konica Minolta spectro I believe?
Yeah, I can probably support it. I’m assuming it can export LAB values. As long as it can do that then it’s all good . . .
Thanks Walker
Yes, this is the Konica-Minolta solution.
I guess it is not that easy. There is no option for loading charts in the software. I have contacted them but did not receive an answer yet.
Will keep you posted when I get it.
-Markus
sounds great
