Piezoflush cleaning kit
I have a Piezoflush cleaning kit for my 3880 and it’s been sitting there for about two years doing nothing. I just noticed as I was perusing through some material somewhere on your website maybe it was in the community edition that the ink ports need to be taped closed. I didn’t do that and I’m just wondering how big a problem that is. What would you suggest.
It’s not a problem with PF as much as it is with ink. Just prime the carts and tape them and you’ll be fine.
