permission denied while trying to install curves
As I tried to install old curves from my older computer in a newer one I keep getting this message: I’m copy-pasting from Terminal window. , cp: /Library/Printers/QTR/quadtone/Quad3880-PiezoDN/3880-PiezoDN-Pd-ArchesPlatine-lin.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/Quad3880-PiezoDN/3880-PiezoDN-PdLinearized.quad: Permission denied
No sure what you are trying to do but this command will generally fix things:
sudo chmod -R 777 /Library/Printers/QTR/quadtone
It will require your password after hitting enter.
I’m trying to install older curves I’ve done before in my older computer in the new computer running a newer Mac OS (Sierra). My older was 10.7.5
So, I must run <span style=“color: #5b5b5b; font-family: sans-serif; font-size: 15.6px;”>sudo chmod -R 777 /Library/Printers/QTR/quadtone in the Terminal module, right ? </span>
Thank you
Pablo
Yes. Run that command in terminal then copy all your curves from the old computer into new computer into >Applications>Piezography>Curves>…
Then run the install command.
it worked !
muchas gracias
This worked for me today, thank you! I was getting an error about cups or something.
Hi.
I try to install PiezoDN new curves with OS BIG SUR and a an Epson P800. .
I give you the message I recieve :slight_smile: When I want to install my new piezodn curves this is the message I get.
I don’t understand what I can do.
------The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
/Applications/Piezography/Curves/P800-PiezoDN-Pro/InstallP800-PiezoDNPro.command ; exit;
macbook-pro-de-michele:~ michelelafaye$ /Applications/Piezography/Curves/P800-PiezoDN-Pro/InstallP800-PiezoDNPro.command ; exit;
Creating printer named: QuadP800-PiezoDNPro as Direct USB Printer
lpadmin: Printer drivers are deprecated and will stop working in a future version of CUPS.
No default ink limit found, using 100
Could not find gray highlight, using 4
Could not find gray shadow, using 4
GRAY_GAMMA missing, using 1
Creating curve Limiter-Master-out
Couldn’t open /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Limiter-Master-out.quad for writing: Permission denied
Couldn’t open /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Limiter-Master.quad for writing: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-ArgyBX.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-Cyanotype.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-ilf_CLASSIC2-limited.quad: Permission denied
Creating curve Pro-PiezoDN-Master-out
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-Master.quad: Permission denied
Couldn’t open /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-Master.quad for writing: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-PtPd-DevOut.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-PtPd-PrintOut.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-Silver.quad: Permission denied
Installing QuadToneRIP Curves Printer QuadP800-PiezoDNPro
Curve Pro-PiezoDN-Cyanotype
Curve Pro-PiezoDN-Ilf-F-classic-Limited
Curve Pro-PiezoDN-Master-out
Curve Pro-PiezoDN-PtPd-DevOut
Curve Pro-PiezoDN-PtPd-PrintOut
Finished Installing Curves for QuadP800-PiezoDNPro
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Opération terminée]-------
Have you an idea what i can do?
Michèle
Dear Michele,
  1. Re-install quad tone RIP
  2. Go to the curve folder and set permissions on the entire folder and its contents to read-write for everyone (you can “get info” on the folder and do this
  3. Run the install command.
best -Walker
Hi Walker
Thank you for your always quick and wise help I followed your advice.
Now I was able to load my new quads.
I wish you a very nice day.
Michèle
Hi Walker
Sunday my printer refused to print between two negatives of the same file. I had just changed the curve in Print tool.
I uninstalled and re-installed QTR and Print Tool. Gave all permissions to the Quads, restored a previous Time Machine. It still didn’t work. The printer swallowed the paper and ejected it without printing. My epson stil accept printing with epson driver. And always this error message about CUPS when installing the curves.
After uninstalling my Epson driver, and re-installing it, everything works again.
But for how long?
Why do the curves I create sometimes appear as .txt files in the curves folder in my Piezographie folder.? On Roy Harrington’s recommendations I deleted them.
Thanks again for. enlightening me in my open dec of this wonderful instrument… too delicate no doubt for my skills.
Michèle
if you save a curve without saving it as “.quad” than it will be “.txt” that is why. If you have a .txt in there it may corrupt an older curve that had been .quad
Hi Walker
I have saved .Quad files in the “curves” folder of PiezoDn Pro. When I wanted to install the new curve the installation program created .text files and even duplicated some of them by creating "in and out.text files ».
Since then on the advice of Roy Harrington I have cleaned up and deleted the .txt files.
I will resume a series of prints of negatives for the Argyrotype process, I will keep you informed.
Best
Michèle
Hi Walker.
I must not be very good, but I can’t install the curves
When I want to install a new curve I get two error messages;
the first one
“Inks mismatch: PPD has K,C,M,Y,LC,LM,LK,LLK and Quad has K,C,M,Y,LC,LM,LK,LLK,OR,GR”
The second one `about install P800
I can read this message
#!/bin/sh
#call the main install script __$0contain directory and printer name
as in Install1430-K6=1400
/Library/Printers/QTR/bin/quadinstall $0
What must i do now?
Best regards
Michèle
Hi Walker.
It seems that it is the installation of theP800 with Air Print that was disturbing the system.
Indeed I had not been vigilant enough during the installation of the Epson printer driver.
I disconnected the wi-fi on both the printer and the computer. So the printers, including the QTR printers, were well installed with the USB port and the dedicated driver.
It seems that it works normally with the curve I created last week. The Argyrotype is still in the water. It seems to be satisfactory.
Thank you very much for your attention and help. (PS: I updated my OS to Monterey last night)
Michèle
