P6000: Cleaning Error: Automatic head cleaning failed
Hello,
Epson SureColor P6000 - I have used PiezoPro and PiezoFlush for a number of years without a issue. I usually put my printer in ‘storage mode’ for about 4-6 months while I’m traveling - install PiezoFlush cartridges, run the PiezoFlush thru the printer and upon my return I install PiezoPro cartridges and run the Pro ink thru and start printing, super easy. Not this time…
I had PiezoFlush installed in the printer while I was gone. I installed a new maintenance tank, turned on the printer, started up as normal, I ran several Nozzle Checks (all good) and then installed the PiezoPro Ink cartridges. I started to run the printer to flush out the PiezoFlush, when I decided to do a head cleaning to speed up the flushing of ink. I now have a “Cleaning Error: Automatic head cleaning failed” message at the end of the head cleaning cycle. My nozzle Checks have printed clear, after this error. Since this Cleaning Error has happened several times, I have done a cleaning of the capping station, wiper, flushing Box and print head ( i have done this cleaning before as my maintenance program). and I still get “Cleaning Error: Automatic head cleaning failed.
Any suggestions??
THX
Jimmy
I’d turn off automatic head cleaning because it’s probably not seeing anything print where GCO is. Run manual nozzle checks and if good you’re good to go.
Thanks Jon, Will do.
