P-600 and bluetooth
It’s possible to print via bluetooth or is this not recommanded and better to connect the printer via USB? Currently I’m using the USB-connection, due to another set-up of computer, printer, … I’m considering the bluetooth connection. Best, P.
It’s always better to print via USB
It’s OK to connect with a ethernet cable the P-600 (equipped with a LAN-port) directly to the MacMini (equipped with an ethernet port)?
I assume that I’ve to re-install the drivers? Do I need also install the Epson drivers?
Thank you.
Peter
you can but you need to share internet from Wifi → Ethernet on your computer in order for your printer to behave properly.
