One more question
In the Workflow Consideration section (PPE linearization) is this: “…targets found in the ColorMunki and Spyder folders will work perfectly,…”.I asked this question previously (with no response) Can the 129 step ColorMunki targets be read with the Spyder?
sure, the ColorMuni targets can work with Spyder as long as you are reading patch by patch
