Negative Numbers in Curve using Blender Tool
I am experimenting with the blender tool, and found that it can produce a .quad file with negative numbers. The print results are quite unexpected and non use-able. Should I have negative numbers ?
Thanks, Tom
If you have blending over 0% or 100% it can do this (or two sharply).
If you have a neg number, change it to zero, or blend less strongly.
