Looking for curves - Awagami Kozo with K5 Pro
We have to print on an Awagami Kozo Thick White 110g paper and we are looking for curves with our K5 pro inks.
Where could we download it ?
If they don’t exist, could you suggest curves to use ?
David
We don’t have K5s yet.
These ones will work well though: https://community.inkjetmall.com/t/piezo-pro-and-awagami-papers/5939
You can do a blend in the highlights with an existing k5 matte ink curve and and then linearize. That should do it to make the K5.
I suggest placing the K5 curve into the starting curve and K4 curve into the blending curve so that you retain the K5 curve header and OR/GR channel definitions.
Thanks for your answer. I will test it as soon as possible.
David
