Hi Y’all - First time for me to post questions. Thanks in advance for the help. I appreciate the community here.
I’m attempting to linearize for gum, for particular pigments and paper. I’ve worked with gum for a bit so am familiar with the nuance and particularities and all of its variables. In a brief exchange with Walker (thank you!) it was suggested that I use the 21 x 16 target and the Pro Tool. I am using the K7 inks in a 3880 with the newer black ink… My questions are:
- Is it better to begin with the Master.quad when printing that target, or better to start with the Gum.quad that was supplied?
- Does it matter which parent folder from the Curves folder I work from, the 3880 PiezoDN, the 3880-PiezoDN-P2, or the 3880-PiezoDN Pro if I am to use the Pro Tools to linearize along with the ink set I am using?
