In step r. of the procedure for limiting a PiezoDN .quad from page 95 of the 2016 Piezography Deluxe Edition Manual: do I copy and paste the entire cgats worksheet located in the piezography_curve_adjustment.xlsb excel workbook or just the data fields?
thank you !
Michael
So the entire worksheet… Thanks Keith!
Not exactly - the entire area that is used, not the entire worksheet. The entire worksheet would be what you get if you type Command-A. You want the entire data area including headings in rows 1-7 and the last row 139, but only columns A-D.
But that’s probably what you meant.
