Ink mapping - 1430
Is it possible to map out the black ink on a 1430 and use 5 inks only? I somehow managed to break the little nozzle which pushes into the cartridge off. Don’t ask how…
Possible. Remap the black channel to the yellow channel and then zero out the black channel. Put Black in your Yellow slot in the printer and run some calibrations. it will be dark shadows the first print . . .
