i1Profiler tray will not work in a future release of macOS
Has anyone seen a solution to the i1Profiler issue that is approaching users of macOS?
xRite left this market and has turned over support of the instruments and software to Calibrite and they have their own agenda. You may want to contact Calibrite and ask if they intend to rewrite the application or will they replace it with a new one.
i1Profiler can easily be addressed by a $35-$75 MacMini from eBay running a pre-Ventura OS. Make sure you do not purchase one that has been upgraded to modern OS X.
In this case you install the old xRite software on it to run your spectro. You will also get better printing from hanging your printers off it. This eliminates the constant OSX ICC interference (or changes) and allows printing targets from applications other than Preview to circumvent that. Of course one can print color targets from PrintTool to circumvent that. But older OSX helps users who have color printers and want to stabilize and potentially improve their ICC color management. It also offers the older interface to QTR which is much simpler to print with and eliminates saved settings issues or any issues surrounding “last used settings” being forgotten. Just a much better workflow to use a Printer server this way.
Here is a link to a tutorial on how to set one up as a shared server so that you can continue imaging on latest greatest and printing from a rock steady.
The tutorial says the Sonoma release broke color management. If that is the case, Ventura would seem to be the last release supporting the older color management. You say in the above message pre-Ventura should be run instead of the current revs. Is there something in Ventura that we should stay away from that release?
Ventura is when settings stickiness began to become wonky. If you’re careful and do not back out of print windows by cancel button they hold but otherwise often reset to default. We have Ventura in our studio but still do not print from it directly.
I am supposing that was beginning of the era Apple techno abandoned paying attention to printing and focusing instead on video and display optimization which is a growing sector.
If you’re in this forum you’re using color management at an extremely high level compared with average consumers who just press print with Eco Tank printers which is Epson largest market. The more sophisticated tools is what has been suffering.
I just bought a 2018 Mac Mini and installed Monterey on it. I obviously need to use it for my iProfiler. I also intended to us to host my Epson 3800 and 3880. You mentioned installing QuadtoneRIP, Print Tool and Piezography Community Edition on the Mac Mini as well. Can’t I continue to run these on the main system instead of moving them onto Mac Mini. If I run the printers on the Mac Mini can I just share the icc profiles that were already on the main system? Thanks!
If you are going to host the two printers on your Mac Mini you would need to install QuadTone RIP, Print Tool, and Community Edition on it to be able to print from it. That is my recommendation vs modern OS X.
If you prefer to run your two printers on your main system and just use the Mini to run iProfiler - you can do that - but with respect to the challenges that modern OS X causes QTR printing - and the eventuality that modern OS X will eliminate all CUPS capability (something it has already begun). At some point QTR will not function on modern OS X. QTR completely relies on PPD profiles to tell the printer how to split tones and partition individual ink channels. So you might want to use the Mini with Monterey and not have an interruption to your workflow when Apple pulls the CUPS plug entirely.
If you are using ICC profiles to print from Print Tool you still need .quads in QTR as well as QTR to print. The ICC just provides a linearization adjustment to the .quads in QTR. Hence, you need make a decision as to where you are going to hang your two printers and whatever you decide is best for you - that is where you install Piezography and QTR software.
OK… I understand. Will the newer revisions of the software that I would be running on the Intel Mac be updated for Intel or will it be frozen in time?
The reason you are using the INTEL mini is precisely because it is not being updated.
There is nothing that you need now on it that will require any updating. And none of what you are using is going to be updated. Beware even Apple pushing you an update. You do NOT need it for anything you are using it for because everything you are using it for is not of Apple concern.
So, you’re telling me that even if I didn’t have some older Epson printers and iProfiler, I would still need to move to an Intel machine if I want to keep using Quadtone RIP, Print Tool, etc?
Because QTR relies on deprecated CUPS architectures that Apple intends to fully drop (like custom print pipelines and PPD-based configurations) to control individual ink channels, native QTR installations are highly vulnerable to breaking on newer versions of macOS.
I am advising our customers to maintain a dedicated, older “print server” Mac (or a Windows PC, where QTR runs as a completely standalone executable (QTRgui) and does not rely on CUPS) to ensure their workflows remain.
Further to this is the superiority of the older Mac printing via saved settings and remembered last used settings when printing on older OS X. I would jump off a cliff if I had to maintain Cone Editions Press on modern OS X. Everything is superior years ago in regards to professional quality printing including COLOR.
Therefore, there are three issues. East of Use, Repeatability, and Deprecation. East of Use is already affected. Repeatability has been affected now for many years on OS X. Deprecation will eventually become End of Life. So prepare now or prepare later. It is purely your decision.
If everything works perfectly well for you on your workstation then just use the Mini for the End of Life iProfiler. When the shit hits the fan and you finally update to something that eliminates CUPS from your workstation you will still have the mini to revert to.
I did not know that those applications depended on depreciated architectures and they were not being maintained. That is information I did not have, Thanks!
