I1pro2 won't calibrate
I am having issues with using an i1pro, technically it is the efi es-2000. I own the ipublish software with a dongle. It will connect and show up as a i1pro2 but when I go to measure and hit calibrate, it fails. I also have an i1pro, the original one. and I have the same problem. I have tried every port on 3 different macs from a 2011 imac to a new macbook pro and it’s always the same. I have tried four different cables, still nothing. I hooked it up to the idiagnostics and the same thing. I have tried regular usb ports and powered hubs. At this point I am not sure what else to do. Does anyone else have this porblem?
Greg
update xrite XRD. Use the top left usb only (not the right one). Use a new cable. make sure no other spectro software is open. Make sure you use i1Profiler 1.8.2 (not 3)
Thanks Walker, I tried all that and it did not work. I ordered a new cable so I will see. I am going to borrow a friends i1pro2 that I know works so I will see if it is the computer or the device.
This is what I get when I run diagnostics:
i1Pro Tests
General Information
Date and Time: 11/15/19 11:23 AM
Application version: 4.1.2.290, 64-bit
SDK version i1Pro: 4.2.4.5061
SDK version i1iO: 2.2.4.5061
SDK version i1iSis: 2.0.0.4942
SDK version ColorMunki: 1.0.3.4630
SDK version i1Display2: X-Rite, Inc. SipCal Library Ver. 7.3.7
Platform: Mac OS 10.14., 64-bit
Open instrument
Connection: Successful
Open instrument: Successful
Instrument information
Instrument inspection: Successful
Serial number i1Pro:
Type: i1Pro
Revision: E
Firmware version: 634
CPLD version: 999
Dark measurement count: 120
Lamp burning time: 8.5 seconds
Spot measurement count: 40
Scan measurement count: 0
Factory calibration: 3/12/14
Spectral Module ID: 01-21bde1150000a6
Supplier: ‘EFI-ES2000’
Warranty start date: 11/20/14 6:55 AM
Recertification date: -
Instrument Licenses
Measurement Modes: [Reflectance Spot, Reflectance Scan, Emission, DualReflectance Spot, DualReflectance Scan]
Licensed functionality: [Has UV LED, Has Wavelength LED, Has Zebra Ruler sensor, Max Ruler Length = 300 mm, Has Indicator LED, Spectral values, Tristimulus, Density]
Licensed Modules:
i1Match Module “Scanner”: NOT licensed
i1Match Module “Monitor”: licensed
i1Match Module “Printer”: NOT licensed
i1Match Module “Printer RGB only”: NOT licensed
i1Match Module “Printer CMYK only”: NOT licensed
i1Match Module “Beamer”: NOT licensed
i1Match Module “Printer Easy RGB”: NOT licensed
i1Match Module “Printer Easy CMYK”: NOT licensed
i1Match Module “Digicam”: NOT licensed
i1Match Module “Editor”: NOT licensed
i1Profiler Module “Display Profiling”: NOT licensed
i1Profiler Module “RGB Printer Profiling”: NOT licensed
i1Profiler Module “CMYK Printer Profiling”: NOT licensed
i1Profiler Module “Printer QA”: NOT licensed
i1Profiler Module “Advanced-Mode”: NOT licensed
i1Profiler Module “Projector”: NOT licensed
Button test
Button: Successful
Emission test
Emission calibration
Tip:
Check if the i1Pro is positioned properly on the white tile!
Is the protection slider of the white tile open?
*** FAIL ***
Have you tested with ColorPort?
yes, it did not work. Neither the i1pro or the i1pro2 will work in any of these. I sent the log files to x-rite and I am waiting to hear back from them.
Hi – any solution to this baffling problem?
Yeah return it and get another one. It was actually never used, with 4 seconds of lamp time. I contacted x-rite and they said that the efi-es2000 should work without a problem. The person I talked to had one and he uses his with no problem. I also borrowed a friends and his worked with no problem so it was definitely the spectrometer itself.
