Hahnemühle Hemp Paper Curves for x900 Pro Ink
I’m wanting to create Piezography Pro Ink curves for Hahnemühle Hemp Paper for the 9900. Edited to add: In the icc profiles for the paper, Hahnemühle instructions say to use Media Setting: Velvet Fine Art Paper at Quality 4 (1440 dpi). My understanding is Piezography printing using 2880 dpi. Should I be looking for a Velvet Fine Art curve or something else?
I did think print the patches using Bamboo Curves, however, it is naturally very warm toned versus the natural bright white of Hemp. Edited to add: What are the implications of linearising using this warm paper curve on a naturally bright white paper?
How do I choose the curve to print the patches with?
So many questions, such a learning curve…
TIA :slightly_smiling_face:
Edited to add: I’m also looking at Moab Moenkopi Washi Unryu 55 gsm paper. On the Moab website, for the SP-9900 it says use Media Type Setting: Enhanced Matte or Archival Matte or Ultra Premium Presentation Matte with MK inkset.
Use the 3 hahnemuhle Photo rag curves. Print all three, linearize all three.
Thanks Walker. Should I also use the same Hahnemühle photo rag curves to print the Moab Moenkope Washi Unryu 55 gsm paper and create curves?
No, use these curves:
https://community.inkjetmall.com/t/working-on-piezography-uncoated-thin-paper-curves/4259
Thanks Walker, I’ll take a look.
Best wishes
