I did a search about grain problems and most of the posts here were from several years back, and I was unclear about the best ways to solve issues with grainy highlights extending somewhat into the mid-tones. I’m using my new 3880, yes that’s right I actually found a brand spanking new 3880 thru an Amazon reseller; still in original box and all the tape and original packing materials, although it did cost me about twice the original cost and twice what a P800 was selling for about a year ago and what a P900 cost now. I went to the extra expense so I could use it as a piezography printer, primarily for digital negatives as my 1400 and R1800 recently died on me. I’m using Pictorico Ultra Premium media, and currently attempting to calibrate and linearize using the Ziatype process and plan on using other alternative processes such as cyanotype and who knows what else in the future, maybe even some silver prints. I’m currently using the selenium P2 inset, although I’m wondering from some of the other posts here I’ve read in this forum if maybe I should switch to the Pro inkset; your recommendations please? I also purchased the Pro Edition of the Software, so I’d have all of the tools available to me.
A little history, I’m not new to digital negatives or making fine prints using QTR, I’ve been in pursuit of the ultimate digital negative for about the past 6 months or so and has occupied virtually all my free time in that time period; not complaining, that’s just my dedication to my art and I don’t mind doing whatever it takes to get the best negatives possible; although it’s starting to wear on me. Before that I had done quite a bit of pure carbon printing using a 1400 on uncoated cotton rag paper (Arches Hot Press), mixing my own 100% carbon inks and using and calibrating with OTR creating the most beautiful prints I’ve ever made, to include silver and palladium. So, the point being, for the past several months I have been mixing my own UV blocking dye based inks to print my own negatives with mixed success, first on a 1400 then a R1800, using several other methods and software programs. The main reason I decided to switch and give Piezography a try was I kept running into issues with calibration and linearization. It’s been somewhat frustrating at times, but I’ve learned a great deal concerning all of these matters in the process. Now with a professional grade printer and all of the tools at my disposal I’m ready to put all of my failures behind me and finally be productive again; at least that is my hope.
Sorry to bore anyone reading this with all of the details above, but I felt I needed to explain my experience and where I’m coming from in order for those that can to give me the best advice possible. Back to my issue with grainy highlights and upper mid-tones, to me it looks somewhat like 35mm Tri-X developed in Rodinal; not a bad look, but not what I’m after since I’ll be scanning 6x7 medium format and 5x7 negatives. As I mentioned above I had linearization and calibration issues with the methods I was using with the 1400 and R1800; however, I never had problems with smoothness of tones, gradations and grain. I understand that the 1400 and R1800 print with a higher resolution with 2880 super and a 1.5 picoliter droplet size verses the 3.5 picoliter droplet size of the 3880, but I don’t feel this is the issue, as I can see the resolution of the 3880, printing some calibration images on film and viewing with a loupe. The resolution, rendering of detail and smoothness of tone is apparent with the 3880, although not quite as good as the 1400, it is still very good and I don’t believe it should cause problems with grain. Although I am hopeful that the Piezography folks will be able to support the new Epson Eco-Tank ET-8550 in the near future, as Jon had mentioned in his last newsletter, while it’s still in production, since it has the same droplet size as the 1400.
If you think about it, when you see grain in a print, you’re not actually seeing the grain in the original negative, whether it be silver or digital, rather you are seeing the spaces between the grains of silver, or droplets of ink, where light is allowed to pass between the grains, or droplets; and the light passing through these “holes” prints as black in a print. I know that’s rather simplistic, but I never really thought of it like that until recently with my experience in printing digital negatives. So it’s the same with a digital negative as with a silver negative, the little black specks one sees in the final print aren’t caused by black silver grains or ink specks on the negative, but rather it’s the holes or spaces that are left between the specks or droplets of ink that causes the black specks appearing as grain in the final print. That being the case, it seems to me the best way to get rid of grain is to use less of the darker inks and more of the lightest shades necessary to produce the same density and “fill in the holes, or spaces”, so to speak. Perhaps I’m wrong, but it doesn’t seem to be so much of an issue of droplet size, within reason, but rather how solid of a pattern one can print, printing with the highest volume of the lightest shade, or shade combinations, of ink necessary to produce a given density, with the least amount space left between the tiny droplets of ink creating a more solid pattern. Please inform me if my assumptions are wrong. Would it be possible to achieve enough density for platinum/palladium printing without the use of the HD PK channel?
At this point what do you believe is my best option, or options, to produce the best possible, and hopefully grain free negatives? Would it be better to switch to the Pro ink set? Other settings I’ve been using are as follows:
Custom paper settings:
Paper Type: Matte/Thin
Platen Gap: Narrow (although I saw it suggested to use Standard in another post and haven’t tried yet)
Thickness Pattern: set to 1
Paper Feed Adjust A&B: both set to 0.00% (I’m assuming these settings are for if you’re having banding issues?)
Drying Time: set to 0.0 sec
Also, I have been using the front feed in order to eliminate the possibility of pinwheel marks. I did see a post where it was recommended to use the rear feed and not the front feed; is this still the case, and if so, why is that better than using the front feed? I am concerned about pinwheels, but guess I should try and see if that will be an issue with my printer or not.
I do apologize for writing a book here, but I just wanted to lay it all out on the table; and I hope that some of my comments may help some other poor souls having the same issues!
Thanks and I do appreciate anyone that takes the time to read my comments and offer any advice they may have concerning the issues I’m having!
Finally, I’d like to volunteer my services if there is still a beta testing group out there and need some additional input.
Best regards,
Randy
