As I have been learning about producing digital negatives using the piezography pro inks, I see that it is recomended to use the GCO for negative production as it helps protect the negative. I was wondering what your experience was by doing this? It is my hope that I could store the negatives for future use when printing silver prints. Will the GCO protect the negatives and for how long? How would you recomend these negatives be stored? Or should I forgo the GCO all together?
sincerely
marty
Hi Marty,
I do not use GCO as a practice as it can slightly soften acuity. The negatives are rather fragile and we do not typically store ours when we make prints for customers at Cone Editions Press because it is a better practice (for us) to have a negative that has not sustained any damage. We use hydration in our platinum printing and the sensitized media is still slightly moist. So on a subsequent printing we may want a fresh neg if we are hydrating in the high 60s rH%. I would harden your negatives overnight - as they do change density. I have our system calibrated for only a one hour dry down. And the negs are a little fragile for same day use but this allows us to take in a project and print it on the same day by calibrating to a one hour dry. I also now have calibrations for 2 day dry. We did some data in November that did give different results for one hour forced dry, one day natural dry, two day natural dry. The negs are a bit more sturdy as well with the 2 day natural as well as tending to have slightly more density that can be calibrated. We store in archival negative sleeves that open from the side so we do not have to slide the neg out. Having said that I am going to give you a good starting point to use to add a GCO to your linearized negatives… You would replace the LLK and all of the 0s following it with the following - as it is only a moderate amount:
#LLK curve
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
9000
8999
8999
8999
8999
8999
8999
8999
8999
8999
8999
8999
8999
8999
8999
8998
8998
8998
8998
8998
8997
8997
8997
8997
8996
8996
8996
8996
8995
8995
8995
8994
8994
8994
8993
8993
8992
8991
8991
8990
8990
8990
8989
8988
8987
8986
8986
8986
8985
8985
8985
8984
8983
8982
8981
8981
8979
8977
8976
8976
8975
8973
8972
8971
8969
8967
8966
8965
8964
8963
8962
8961
8960
8959
8957
8955
8954
8952
8949
8946
8943
8941
8937
8933
8930
8927
8924
8921
8919
8916
8911
8907
8904
8900
8897
8894
8891
8886
8881
8877
8872
8870
8867
8863
8859
8854
8850
8845
8841
8837
8833
8830
8825
8818
8812
8806
8801
8796
8792
8786
8780
8776
8772
8764
8758
8751
8745
8740
8734
8726
8716
8706
8697
8686
8677
8664
8655
8648
8637
8623
8609
8594
8580
8568
8559
8550
8536
8517
8498
8481
8456
8434
8414
8391
8371
8346
8309
8270
8208
8145
8093
8026
7959
7861
7694
7460
7062
6633
6224
5870
5631
5306
4540
3217
0
and others may have different experience especially if they tend to store negatives.
Kind regards,
Thank you Jon
sincerely
marty
