Error in creation of ICC
after saving as .it3 file the data when i drag and drop them into Piezo ICC app it doesn’t do an icc because detect an error but i can understand which is .
may you help me ?
Thank you,
Romano
Piezography-21x16step-i1Pro2_comma_M0.txt (18.6 KB)
may you help me to understand which Is the problem when i try to create ICC file? If i use the same txt file with QTR - ICC app , it works well and i have my ICC but i don’t know if the quality Is better/the same/ worst than that i can obtain with ti3 file .
Thank you,
Romano
