My Epson 1400 needs a couple of head cleaning cicles, but I’m unable to figure out, how to do that on Mac :-(.I searched internet a lot, but I just wasn’t able to find where I can get Epson Utility.
Thank you in advance,
Marko
Marko
Hmm, something must be missing on my computer. These are the only options I have under “Options and Supplies”.
On the other hand, I found how to activate head cleaning with printer’s buttons.
Marko
Marko,
Did you install the Epson driver? The Epson Printer Utility is part of that. That is the only reason to install the Epson driver, but it is useful.
Hi Keith,
No I got it in Apple updates. I’ll check the Epson driver then. Thank you.
Marko
Click the Apple logo in the upper left corner
Click System Preferences. Then click Printers and Scanners. Select your printer.
Select Options and Supplies. Select Utility. Select Clean Print Heads.
