I just bought PiezoDN and have an Epson R3000 and have ink set selenium method 3, ie x.5 inks.
Can I use the 3880 curves and shifts the curves to get it right?
Bests Christer
Bests Christer
PiezoDN uses shades PK and selenium 2,3,4,5,6 and Gloss Optimizer.
However, there is a set of converted Meth3 curves in the Curves folder that will work with your inkset. These special Meth3-PiezoDN curves can be calibrated just like the standard PiezoDN curves.
Please read the manual for more detailed information.
Regards,
Thank you Walker. I’ll do the home work.
However this time I made it a bit more complicated because I also setting this up in an iMac. Earlier I’ve used QTRRip in a PC together with piezographic selenium inks doing negatives. So there’s a lot to learn.
My intention is to use this together with Pt/Pd and Carbon printing in the end
