Anyone every use an Epson Perfection V600 Photo Scanner to calibrate PiezoDN? Will that scanner work for this?
I tested with a V750 scanner, but the internals are just about the same. Should work fine.
You just have to make sure that you scan with no adjustments. Turn all the auto levels, etc, off.
