After creating a new profile curve in PPE, I copy it to a Sublime text document and save it to my curves folder. The command to Install the curves no longer works. My mac just updated to Ventura 13.2 and this is when the problem started. I have the latest versions of Print Tool, QTR and Sublime text on my Mac.
Any ideas how to install the new curves? I did try to just copy the new curve into the QTR folder in the library, but Print Tool does not see it using this method.
Many thanks
David
Here is the error message from the Install Command in Piezography Curves:
Last login: Tue Feb 7 14:11:41 on ttys000
/Applications/Piezography/Curves/P800-PiezoDN-Pro/InstallP800-PiezoDNPro.command ; exit;
The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
Davids-Mac-Mini:~ dsmini$ /Applications/Piezography/Curves/P800-PiezoDN-Pro/InstallP800-PiezoDNPro.command ; exit;
lpadmin: Printer drivers are deprecated and will stop working in a future version of CUPS.
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-Cyanotype.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-Master.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-PtPd-DevOut.quad: Permission denied
cp: /Library/Printers/QTR/quadtone/QuadP800-PiezoDNPro/Pro-PiezoDN-PtPd-PrintOut.quad: Permission denied
Installing QuadToneRIP Curves Printer QuadP800-PiezoDNPro
Curve Pro-PiezoDN-Cyanotype
Curve Pro-PiezoDN-Master
Curve Pro-PiezoDN-PtPd-DevOut
Curve Pro-PiezoDN-PtPd-PrintOut
Curve PtPd-Hahn_DevOut_2022_01_24a
Curve PtPd-Hahn_DevOut_2022_01_26
Curve PtPd-Revere_Fe1_2023_01_27
Curve PtPd-Revere_Fe1_2023_02_07
Finished Installing Curves for QuadP800-PiezoDNPro
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Process completed]
