The attached image shows the 3rd printing of the purge target after doing an initial fill with the Epson Service software.
Is the color of the Ink 4 Yellow correct? I assume it should be the warm brown color.
The Yellow and Orange carts are the two that were defective and were causing my P9000 to continually pressurize. Does the purge image indicate those two channels did not replace the Epson color inks when I did the initial fill?
Should I run a 2nd initial fill where I select the Yellow and LLK channels or just continue printing purge targets?
Drew Harty
