Connect and print over Bonjour?
Hi @walker
Is it possible to connect and print to my 9900 via Bonjour - I can see it on the network and add it as a Quadtone printer, however, cannot install any curves using the Install9900-ProK5 command. I’m thinking this is because it’s only USB??
Thanks in advance
  1. Plug your printer into your computer via usb.
  2. Run the install command from the specific curve folder you are using.
  3. If you are wanting to print from another computer to this printer share the printer from the first computer and you will see it when you add a printer on your second computer.
This is the way to do it.
