Color balance with new head
I just replaced a head on the Epson 9900. So far it seems to work great, but when I try to use the same blending options, I get a color cast. I have added the VLK cool and warm and I flushed the lines of any ink I have changed. I was wondering if you could tell from my profiles if the inks have been fully flushed?
Greg
x900-Hahn-GermEtch-Cool_21_12_27_51.quad (7.3 KB)
x900-Hahn-GermEtch-Nuetral_21_12_27_51.quad (8.9 KB)
x900-Hahn-GermEtch-WM_21_12_27_51.quad (7.3 KB)
x900-Hahn-GermEtch-CL_base_12-27-51_M0.txt (3.3 KB)
x900-Hahn-GermEtch-NU_base_12-27-51_M0.txt (3.3 KB)
x900-Hahn-GermEtch-WM_base_12-27-21_51_M0.txt (3.3 KB)
I can’t really tell here but did you make sure your carts have been agitated regularly and/or before each printing session?
Thanks. I just installed all new inks and shook them before I put them in the cartridges. I do shake them each week.
Greg
Sometimes the dampers can get a drift of cyan that comes out all at once during a head/damper change . . . it should resolve though,.
