As suggested, I’m checking out my printer using the installed inkset. Nozzle check and ink pattern page for starters.
I’m on windows and I used QTRGUI to print using calibration mode. For this initial test, I printed on photocopy paper. I just wanted to see if something was wrong or not as the nozzle check routine (Epson tools) wasn’t quite right.
I immediately notice the magenta and yellow ink where the wrong color, others seem fine. I’d like to know if I’m in trouble? I bought the cleaning kit (not in yet) but maybe I should not waste it on this printer?
Here are the 6 colors I get, maybe this will give you an idea of what’s wrong.
CGATS.17
ORIGINATOR “i1Profiler - X-Rite, Inc.”
INSTRUMENTATION “i1Pro 2 ; Serial number 1104157”
DESCRIPTOR “1430InkValues”
MEASUREMENT_SOURCE “MeasurementCondition=M0 Filter=no”
ILLUMINATION_NAME “D50”
OBSERVER_ANGLE “2”
FILTER “no”
WEIGHTING_FUNCTION “ILLUMINANT, D50”
WEIGHTING_FUNCTION “OBSERVER, 2 degree”
KEYWORD “DEVCALSTD”
DEVCALSTD “XRGA”
CREATED “2021-08-22T08:22:21”
NUMBER_OF_FIELDS 8
BEGIN_DATA_FORMAT
SAMPLE_ID SAMPLE_NAME XYZ_X XYZ_Y XYZ_Z LAB_L LAB_A LAB_B
END_DATA_FORMAT
NUMBER_OF_SETS 6
BEGIN_DATA
1 A1 6.045 6.065 5.421 29.57 2.18 -2.12
2 B1 12.890 15.609 35.826 46.46 -13.55 -43.76
3 C1 10.581 9.454 19.626 36.84 11.60 -32.80
4 D1 10.976 11.539 4.975 40.47 -1.10 18.95
5 E1 19.596 26.019 50.283 58.05 -25.23 -41.88
6 F1 41.575 26.252 24.727 58.28 57.58 -5.77
END_DATA
