Hello Walker,
I am having an issue with the C channel on the 9900, and since I have no plans now to print glossy, I thought I would map the C channel to the LLK channel where the gloss optimizer sits unused. My approach is as follows:
place the chip from the LLK cart onto the C cart and place into the LLK slot,
using print tool, purge print the gloss optimizer out of the line/damper/head replacing it with cool dark ink,
write 0s into the C channel of the curve I am using, paste into the LLK channel the values from the C channel,
linearize.
Is this the best approach ?
Tom
