Canson Ed Etching Cool Curve for P9000 with ProK5 inks
Recently installed PiezoPro K5 in my P9000 and initial tests all look good. Looking for curves for Canson Edition Etching but only see Warm and Neutral in my Curves folder and doesn’t appear in QTR. Has that curve been created or is there something else I’m missing?
Michael
Sorry, will update in the next one:
x900-Canson-EdEtch-Cool.quad.zip (2.2 KB)
Thanks Walker! My printer is the P9000, not a x900, so are you recommending I use this curve until the next update?
You’re probably aware, but I’ll add the other papers I use that I found P9000 ProK5-Cool curves missing: Canson Rag Photographique , Hahnemuhle Photo Rag Baryta (although I did find a Cool NWCGO for that one which I haven’t tried yet).
It’s the 7900 9900 curve, will work on your P9000 (same curve/printer)
Thanks, will add to the curves.
M
