About ink replacement
I used normal Photo Black Shade 1, but I would like to change it to HD ink.
Is there a command to insert HD Photo Black into a new cartridge and insert it into the slot of Shade 1 and take out Photo Black ink remaining in the tube?
I am using 4880.
And can I use x8 - P2 - PiezoDN - Master.quad with HD ink as it is?
You can purge just the K ink by printing purge sheets through QuadtoneRIP.
https://community.inkjetmall.com/t/how-to-flush-individual-channel-using-qtr-calibration-mode/2070
You can also use the same Master curve.
Thanks walker .I will try.
